Is it possible to enable/disable the TPS7H1101A-SP device using the Soft-Start pin as it was done for the old TPS7H1101-SP device? We wish to use a transistor to pull the SS pin to ground when disabling the device. The TPS7H1101-SP data sheet shows this method; the TPS7H1101A-SP data sheet left it out for some reason.
Jim Becker
