Isolate Gate Driver design
Other Parts Discussed in Thread: UCC21225A
TI & Delta Technical Roadshow (9/20) in Tainan Delta.
It talked about the • Isolate Gate Driver design.
How to choose the Dboot,Cboot and Rboot.
thx!!
  • Hi Juncheng,
    Thanks for reaching out to us, my name is Mamadou Diallo and I will help address your concerns.
    Out of curiosity, how do plan on using the isolated gate driver? (What application?) Which isolated gate driver are you planning on using?
    As a starting point, I've attached couple documents for your considerations that you might find helpful.
    The first one discusses methodology for half-bridge configurations which will be applicable to your case as well
    www.ti.com/.../slua887.pdf
    The second below is the datasheet of one our isolated gate driver UCC21225A where section 9.2.2.2 discusses the selection of the boot diode, Cboot and Rboot.
    www.ti.com/.../ucc21225a.pdf
    Please let me know if you need further assistance with your design or press the green button if this helped address your concerns.
    Thanks.
    -Mamadou
