Hi, I am using BQ76PL455EVM for monitoring cell voltages, and I want to build a battery stack of 210 LiFePO4 100Ah cells in series. I am writing my own fuel gauge algorithm, as well as capacity and impedance estimation algorithm for each cell using data from bq76pl455 ICs. Could you recommend me what evaluation boards should I buy so I can compare results and test my algorithm? I want the algorithm to be as accurate as possible for cells of different health and age. One cell to test on is enough, but maybe better to use a board that evaluates multiple cells simultaneously. It would be best if the fuel gauge evaluation board could connect directly to PC, but if not, I will use the appropriate interface board, no problem.
Thank you in advance.
Mislav Blajic
