Hi all
Would you mind if we ask TPS3808?
On the datasheet P12, there is the description "The pullup resistor should be no smaller than 10 kΩ as a result of the finite impedance of the RESET line."
If the pullup resistor is less than 10kohm(for example 5kohm), what kind of problem does it occur?
Kind regards,
Hirotaka Matsumoto
