Dear sir,I have a problem of TPS23880,in this code:
else tps_SetDevicePowerOn Is there any logic here?
Hi David,
As we set channel5&6,7&8 as 4 pair ports, as long as we see valid classification on either of these channels, we turn on both channels at the same time. For 2 pair port operations, you can refer to channel 1-4. Thanks.
Penny
Hi David,
You can write to register 0x19 after the external switch is turned on. Depending on whether the PD is IEEE standard or not, you need to set the device operating mode to semi auto(for standard PD) or manual(for nonstandard PDs). Thanks.
Penny
