Xilinx Kintex 7 FPGA XC7K160T power solution
Other Parts Discussed in Thread: TPS65023, TPS650864, TPS650861
 Hello Team ,
For one of our customer project  based on  Xilinx Kintex 7 FPGA XC7K160T-1FFG676.  We require support in designing the power scheme. We are planning to use TI Switchers and regulators for the same.
Do we have any PMIC / power solution for supporting XIlinx Kintex 7 series FPGA ?
  • Hi Shreenidhi,
    Yes solutions are available, you can use the following link to find solutions for this and other xilinx devices:
    www.ti.com/.../xilinx.html
    The following reference design is specifically for kintex-7, using discrete components. Alternatively, customers could use something like the TPS65023 to support multiple rails.
    http://www.ti.com/tool/PMP7978
    Rick S.
  • Shreenidhi,
    I see you already looked at a question on the Zynq Ultrascale+ and asked this as a follow-up question.
    The TPS650864 can be used in most of the large, power-hungry Xilinx applications. We have recently been working on power proposals for the latest Kintex UltraScale+ (KU+), and below is a solution using the TPS6508641 to provide power to the KU3P-KU15P devices in the KU+ family.
    Since the Kintex-7 is an older version of the KU+ family, there will be a lot of similarities in the design.
    If you find that the TPS6508641 is not wired exactly as it should be in your design (because the core & DDR voltages are higher), you can look at the TPS650861 customer-programmable PMIC to develop your own custom PMIC solution.
    The is also a getting started video tutorial titled TPS65806100: Customer Programming of Multi-rail Power Management ICs.
