LMZM33606: Negative Output
Part Number: LMZM33606
Can I use 2 of LMZM33606's for making a DC-DC converter with positive and negative outputs: +15V and -15V, 4.0A each?
  • Hi Lalith,
    Yes you should be able to convert one of the LMZM33606 for negative inverting application. However, you might be limited in the amount of current you can pull for a -15V output configuration. For reference please take a look at this app note.
    Jimmy
