BQ24075: How to continue charging the battery but stop the power to device while usb is plugged in
Part Number: BQ24075
I have to create a fail safe option for my battery powered device where when I plug in the usb to charge the battery the device is not usable (powered down). I Have thought about using a MOSFET on the output pin of this device and use the PGOOD signal to cut off the Vout from going into my system. However, MOSFETs in general fail in short position! Do you have any suggestions? is there standard way of doing this?
