Hai,
I am using TPs560200 ic as my 3.3v power supply.When i probed the 3.3v power supply i found that ,there is noise in the output voltage.I have followed same routing topology and have used the same component values as per datasheet.What could be the possible reason for the cause of noise in the power supply.How can i purely filter out the noise and remove those noise in the output?How should i choose the cap values to filter out the noise levels in the ouput?
