Other Parts Discussed in Thread: UCD9090A
We have received our boards, where we use TPS543C20 to generate core voltage for an FPGA (0.9V).
On boards, where the FPGA is no soldered in, the power supply works well, the switching starts 4 ms
after the rising edge of the enable signal, just as we set by pin strap resistor.
Meanwhile on the other board, which assembled with this FPGA the TPS does not seem to start at all. No signal
on the switching node. What problem can possibly block TPS start-up? We have investigated further by breaking the
sense line, or grounding the output capacitors...both in these cases TPS started switching.
thank you in advance.
Peter
