Dear,
TPS650942 Could need IC Programming?
If need, PLease share to me.
Lawrence.
Dear,
Lawrence.
Lawrence,
The TPS65094 has one time programmable (OTP) memory that is programmed in at the factory. The different variations like the TPS650942, TPS650941, etc. are all different OTPs. No programming is needed on the customer side to get the device running.
Voltage levels, sequencing and other settings can all be changed once the device is powered up, but after a power-on-reset it will load the program that was programmed into OTP memory at the factory.
Thank you,
Nick
