I'm facing the issue related to Fault output.
when the input channel 1 is HIGH corresponding channel 1 Switch output is LOW (remaining 3 channels output are in HIGH only ),as per the datasheet Fault output should be LOW but while testing Fault output is in HIGH state only.
could you please help me what are the possibilities to happen this condition .and we have measured the voltage across the Vs pin and channel 1 output it shows Vs itself (open condition)
Thank you for your response in advance.
