Team,
could you please support with the question below?
I'm looking to implement a dimming pattern for each LED channel by periodic rewrite of PWMx value.
Do you see any reason why this shouldn't work with the TLC59116F?
Thanks and best regards,
B
Team,
B
Hi Basil,
Have you set the LDRx? the value should be 10/11 if you want to adjust the brightness through PWMx.
If you have noticed this. what is the frame rate that you rewrote the registers?
Could you give more information, such as codes to help to find the reason.
Thanks!
Best regards!
Shawn
