Hi. I'm designing a board using the above-mentioned fuse. I'm wondering if the cap value for the VOUT has to be 470uF. The input voltage is from a low-ripple battery, and will never go above 18V. Can the output cap therefore be lower? This is largely a space consideration. Thank you.
