Search for a component reference are device Marking CDVX.
Other Parts Discussed in Thread: TPS61178
Hello Madam, Sir, I'm looking for a component surely a controller and voltage increase but I have only the Marking Device 'CDVX' other 15R1 and TI 811 masking, the case is composed of 16 pins dimension 4x4mm, but the pins are distributed on 4 sides in 5 pins and 3 pins. could you tell me the reference of the component please?
Beien cordially
  • Hello Yannick,
      Using the Part Marking Tool: http://www.ti.com/packaging/docs/partlookup.tsp  , and 15RI (instead of 15R1 ), I find the TPS61178:
    Part numberMarkingPackage | pinsStatusDescription
    TPS61178RNWR 15RI RNW | 13 ACTIVE 20-V Fully Integrated Sync Boost with Load Disconnect
    This is a power converter device, as you suggested, and I recommend you explore the Product Folder page for technical information to verify this is indeed the device you have: http://www.ti.com/product/TPS61178/samplebuy#topsidemarking .
    If there is still a question, please send a picture of the device.  And for my information, curious as to why you are trying to identify this device?  Creating a new design?  Or debugging a failure?
    At your service,
    ~Leonard
  • Hello Leonard,
    I thank you for the information, the component seems to be the one I'm looking for. Indeed, I tried everything to find it in the sense of changing the 1 in I.
    I am looking for this component for the new design after a prototype or I used a step-up module. I want to make a clean pcb for the next phase.
    Thanks again.
    Best regards
    Yannick
