LMC6953: LMC6953
Part Number: LMC6953
I'm using LMC6953 Local Bus Supervisor IC on my board. This device has an operating temperature range of 0 to 70C. Does TI carry this part in Industrial Temp?
Do you specifically have an equivalent local bus supervisor IC for PCI Express?
Thank you very much
Ray
  • Ray,
    The device is rated for operation at -40C to 85C. The DC ELECTRICAL CHARACTERISTICS table on page 3 of the datasheet shows the specs at both 0C to 70C and also for -40C to 85C. The accuracy degrades slightly at the wider temperature range but the device is still functional and guaranteed to meet the specs in the datasheet.
    I will work on getting the temperature range changed to -40C to 85C on the product folder and at the end of the datasheet where the samples and orderable information is listed.
    Please let me know if you have any other questions or need any additional support. Thanks!
    -Michael
