TPS3710-Q1: Layout Example
Guru 29720 points
Part Number: TPS3710-Q1
Hi Team,
Figure 19 Layout Example isn't consistent with WSON pin assign.
http://www.tij.co.jp/jp/lit/ds/symlink/tps3710-q1.pdf
I believe it is for DDC package of non-Q1(non-auto).
It is just information that my customer pointed out.
Yaita
  • Hi K.Yaita,
    I believe this to be true. I have confirmed that the pin assignment for the WSON TPS3710-Q1 is correct on the datasheet and the layout example is not a correct representation of the device pin outs. I will work on updating the image. Thank you for letting us know.
    In the mean time, if your customer needs a layout example I would suggest looking at the current example from a bottom view. Since the pin-outs from the DDC package is mirrored, a bottom view perspective is also valid.
    Hope this helps,
    Ethan
