BQ24073: BQ24073 TMR
Part Number: BQ24073
Hi sir,
about BQ24073 TMR setting question, as the spec Rtmr  is set Between 18k to 72k, if IC continue charge time is up to maxim time we set, this IC will be shut down stop charge or re-power and then charge again??
if re-power up and charge again, how much time from re-power up to charge?
whether we can set Rtmr out of 18k to 72k range, if we set the Rtmr is out of this range,such as less then 18k or more than 72k, what will be the effect for IC or battery or system? thanks
