Part Number: TPS54331
Hi TI EE:
When I use TPS54331DR as 5V Vin to 1.2V Vout buck IC,I want to use another power rail 3.3V to control the UVLO point.
When the 3.3V power rail raise up to 2.8V ,the TPS54331DR will start to work and when the 3.3V Power rail fall down below 2V,the TPS54331DR will shut down.
Please help to make sure if that setting is reasonable.
Thank you very much.
Best Regards
Cheney_Sun
