LM74700-Q1: negative power on anode
Part Number: LM74700-Q1
hello,
my customer wants to know if LM74700-Q1 will be damaged in case negative power -15VDC is applied on anode case. According to the customer, he tests reverse voltage applied on the system and check if any damage is happened.
when i looked at the datasheet, it says -65V ANODE to GND abs max. Does it means LM74700-Q1 has no damaged in case -15VDC power supply applys on ANODE.
regards,
T.Imi
