UC2825A-Q1: high temperature problem
Part Number: UC2825A-Q1
Hi team,
one of my customers has detected that IC PWM generator reaches quite high temperature at the moment of being powered.
In this application, the PWM generator is controlled by an analog setpoint supplied by our 28335 DSP. If they fix this setpoint to a very low analog value, they inhibit the PWM.
Even when it is not delivering the PWM pulses, whenever it is powered it reaches a temperature about 65ºC.
Is it a correct behavior?
if you need other info, please let me know.
Thanks a lot.
Massimiliano De Cristofaro
TI Staff Field Application Engineer - WEU
