TPS92610-Q1: About TPS92610-Q1 FAULT pin status
Part Number: TPS92610-Q1
Hello Team,
Please help us to recommended voltage level on FAULT pin of TPS92610, since we need to have high to low level for BCM, thanks.
1. The fault pin folating.
2. The fault pin connect cap to the ground.
    The fault pin voltage range with 1uA external pulldown current is shown below. the Fault pin is floating, the voltage is almost the same.
    The fault pin pullup current is quite low. We do not recommend connecting any cap to the fault pin.
