Hi TI,
Could UCC24612 work with TI PoE solution TPS2375x series ?
Is there any limitation while using UCC24612 with TPS2375x?
Thank you.
C.T.
Hi TI,
Thank you.
C.T.
If work in DCM flyback, then the switching frequence could highier than 100KHz, am I right?
Thank you.
Yes, if DCM flyback, switching frequency can be much higher, and should be very ok even over 500kHz.
