Other Parts Discussed in Thread: TPS544B20
Could you tell me about questions from our customer?
· Can the TPS544C20 / TPS544B20 turn ON / OFF the power only by controlling the CNTL pin?
· Is it necessary to set in advance via PMBus with TPS544C20 / TPS544B20? If yes, please tell me which address setting is necessary.
· If the value is saved in the built-in EEPROM after executing the above setting, is it possible to turn ON / OFF by controlling the CNTL pin only after the next startup?
Yuto Sakai
