Other Parts Discussed in Thread: TPS60151
I would like to use LMZ31530 for FPGA supply with 0.9V rail output. My concern is with its output regulation. Output is adjustable with Vadj Pin(by connecting single Rset resistor to AGND) and it is dependent on PVIN input voltage. My application works on battery and hence PVIN may vary with discharging of battery (Variation is 4.2 to 3V). And hence output will also change accordingly. Would you please suggest or clarify how would i make sure that output remains constant with PVIN Variation?
