Other Parts Discussed in Thread: TPS51362
May I ask that if there are ways to improve the Jitter of this part?
Please see below capture for schematic and waveform and let me know if further information needed.
Thanks for your help.
What's the loading about your test waveform?
And could you please share your layout for review?
Hi, most parts looks OK, just the PGround and Aground is not cut very clear. and L9/L11 should be Ground, right?
So far,I am not sure what cause this. I suggest to do some action to check.
1, disconnect R546 100ohm
2, if change item1 not improve, change R544 and R545 to 100ohm. or connect Gsense/Vsense to Vout to try to check whether related with sense line.
