TPS7A47: LOW NOISE LDO
Guru 13485 points
Part Number: TPS7A47
Other Parts Discussed in Thread: TPS7A33
Looking for right/recommended LDOs:
1)Positive LDO,
  • Input voltage 9-12Vdc.
  • I max <1A.
  • PSSR>70db.
  • Adjustable V-out.
  • Good thermal resistance.
  • Small size.
2)Negative LDO,
The input voltage is  ~-5VDC, all other demands are the same as the positive ldo.
I found   the  TPS7A4700, TPS7A4701 and TI_tps7a33.
