Other Parts Discussed in Thread: TPS92691-Q1, TPS92515, TPS92518, LM3409, TPS92691
Im looking at using the TPS92661-Q1 to control a mixed colour matrix of lumiled luXEon C LEDs (4 mixed colour 10 LED arrays)
it looks to me that by default (before configured) TPS92661-Q1 will short across the led driver and the effective forward voltage across the led array will jump whenever any led is switched
ive seen mention of using a TPS92515 but, that means the input voltage must be greater than the total LED forward voltage
i have a previous buck-boost circuit using a TPS92691-Q1 originally from webbench for this led array but am unsure if will work with the TPS92661-Q1
what would be the recommended driver for use with this chip and is it possible to get webench to create a circuit for it
