Part Number: BQ20Z75
Dear team,
A customer now has an old battery (using the BQ20Z75 solution), which causes serious battery feeds due to long inventory times and no power-up maintenance. The solution they consider is to let the battery enter Shutdown Mode when the battery is stored, and increase the Shutdown Voltage voltage to extend the storage time. After entering the Shutdown Mode, the charge and discharge MOS is turned off. If the battery is inserted into the board, can it be normal charging? If not, how do I exit Shutdown Mode?
Could you please help answer this question?
Thanks & Best Regards,
Sherry
