LM5110: clamping body diodes
Part Number: LM5110
Would you please advise if clamping body diodes are present on the OUT_A and OUT_B pins? i.e. if the device is unpowered will the outputs be clamped to a diode drop from 0V?
  • Hi Dylan,
    Thanks for reaching out to us, my name is Mamadou Diallo, I am an applications engineer with the High Power Drivers group.
    Figure 17 of the driver's datasheet models the output stage where the body diodes of Q1 and Q2 help clamp the output of the driver and prevent damage from undesired negative transients.
    Please let us know if you require further assistance or press the green button if this helped address your concerns.
    Thanks.
    -Mamadou
  • Hi Mamadou,
    Thanks for this clarification. I just wanted to be sure that this figure was correct as I could not see any details in the electrical specifications tables.
    Thanks for your help.
    Dylan
