Other Parts Discussed in Thread: BQSTUDIO,
My customer has the following question:
I have an application that will use bq34Z100G1, which has two communication interface. The host device will use HDQ to communicate with bq34z100G1. The MCU built-in with the battery is used to convert the LED display per customer requirement. To avoid bus collision on HDG, I am thinking to use I2C bus to read SOC and current for LED display. Do you know if this is feasible?
Chuchen
