BQ34Z100-G1: Programming srec file into BQ34Z100-G1
Part Number: BQ34Z100-G1
I have questions about the programmation of the BQ34Z100-G1.
I would like to send a srec file to the BQ with Labview. For this, I use the subclass to send data.
But I don't know which adress correspond to the data of the subclass in the srec file.
Do you have a mapping memory for the BQ, or can you help me to send the srec file to the BQ.
Aurelien
  • Hi Aurelien,
    Please use bqStudio to export the SREC as a BQFS/DFFS file and then use labview to parse the i2c commands from the BQFS/DFFS file. If you want to program both the firmware and the settings, use the BQFS, if you already have the firmware on the device and just want to program the data, use the DFFS.
    Sincerely,
    Bryan Kahler
