LP5024: Internal LDO for IO
Part Number: LP5024
Hi Team,
Can you please confirm that the internal LDO in the LM5024 (per the datasheet) applies to the I2C lines?
Since SDA/SCL is fixed at 1.4V logic high, that is my assumption, but I did not see it explicitly stated anywhere.
The goal is to be able to have a higher VCC voltage then your I/O voltage (eg, VCC = 3.3, I2C = 1.8V).
Regards, Diego
