TPS62172: Absolute Maximum Ratings: SW
Guru 29720 points
Part Number: TPS62172
Hi TI member,
My customer found SW pin voltage exceed VIN+0.3V in normal operation.
I would like to send waveform if it is acceptable for TPS62172 or not.
Note) He uses a probe that has minimum ground loop in this case.
Could you send me a private message?
I will put my e-mail address if you can't.
Your support would be appreciated.
Yaita
