When the battery voltage is lower than the minimum system voltage which is set in MinSystemVoltage Register, the charging current at this time is very small.
How to increase the charging current?
When the battery voltage is greater than the minimum system voltage, the system will be charged by the big current which is set in IIN_HOST Register.
My register configuration and schematic are as follows:
Many thanks
