TPS82140: TPS82140
Part Number: TPS82140
Other Parts Discussed in Thread: TPS82150, TPS82130,
Dear Madam/Sir
Could you give me an explanation why there is an problem with the availability of this component. Are there issues in the design or is it an production failure ?
The problem is that I used this component in a new design based on your evaluation board and your announcement that they will be available.
So at this moment I can not finish the assembly and deliver the proof of concept to my customer. Could you please advise if you have a pin for pin compatible device that is available ?
Best regards
Eelco Timmer
