Other Parts Discussed in Thread: LM5146, , UCC27712, LM5143-Q1, LM5145, LM5117-Q1
Hi team,
My customer has an application question regarding DEMB function of the LM5146-Q1 when external driver is used. My customer wishes to use external driver with LM5146 due to the SW & BST rating is not enough for their application.
In our previous experience, when external driver is used the SW pin tends to be grounded, however the DEMB function will not work because SW detects the zero-crossing when hitting the zero current. But now it is grounded which cannot detect the zero crossing anymore
Would you please suggest a circuit to achieve DEMB function while external driver is used? They tends to use UCC27712 for the external driver.
Thank you!
Wei-Hao
