Hi team,
It seems the current Fusion Digital Power designer (v7.1.1) does not support this device yet.
Could you please confirm this?
When will it be supported?
Thanks for your support.
Pol
Hi team,
Pol
<?xml version="1.0" encoding="utf-8"?> <ProjectData xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <Version>1</Version> <Timestamp>2018-11-14T15:03:39.8667087-05:00</Timestamp> <Creator>Texas Instruments Fusion Digital Power Designer v7.1.1.0 [2018-09-17]</Creator> <Devices> <Device> <PartID>TPS549D22</PartID> <Address>21</Address> <Is_Offline>true</Is_Offline> <SAA_Number>1</SAA_Number> <Write_Protected>false</Write_Protected> <Package>0</Package> <Num_Outputs>1</Num_Outputs> <Parameters> <Parameter> <ID>VOUT_MODE</ID> <Code>32</Code> <IDAndCode>VOUT_MODE [0x20]</IDAndCode> <ValueText>EXP =-9</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x17" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>CAPABILITY</ID> <Code>25</Code> <IDAndCode>CAPABILITY [0x19]</IDAndCode> <ValueText>Max Bus: 1000 Khz; PEC: Yes; SMBALERT#: Yes</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0xD0" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Manufacturer</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>TPS59X20_MFR_SPECIFIC_00</ID> <Code>208</Code> <IDAndCode>MFR_00 [0xD0]</IDAndCode> <ValueText>0</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x00" /> <ParameterType>Raw</ParameterType> <ParameterCategory>User</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>TPS59X20_MFR_SPECIFIC_01</ID> <Code>209</Code> <IDAndCode>MFR_01 (PGOOD_DLY) [0xD1]</IDAndCode> <ValueText>POD:1024µs [010b], PGD:1024µs [010b]</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x12" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>TPS59X20_MFR_SPECIFIC_02</ID> <Code>210</Code> <IDAndCode>MFR_02 [0xD2]</IDAndCode> <ValueText>CM: True, HICLOFF: True, SST: 0x00, FORCESKIPSS: True, SEQ: False, TRK: False</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x13" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>TPS59X20_MFR_SPECIFIC_03</ID> <Code>211</Code> <IDAndCode>MFR_03 [0xD3]</IDAndCode> <ValueText>FS:650kHz [011b], RCSP:R ÷ 1 [01b], DCAP3:True</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x93" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>TPS59X20_MFR_SPECIFIC_04</ID> <Code>212</Code> <IDAndCode>MFR_04 [0xD4]</IDAndCode> <ValueText>DCAP3_Offset:0mV [00b], DCAP3_Offset_Sel:True</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x80" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>TPS59X20_MFR_SPECIFIC_06</ID> <Code>214</Code> <IDAndCode>MFR_06 [0xD6]</IDAndCode> <ValueText>VDDUVLO:4.25V [101b]</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x05" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>TPS59X20_MFR_SPECIFIC_07</ID> <Code>215</Code> <IDAndCode>MFR_07 [0xD7]</IDAndCode> <ValueText>VTRKIN:1.25V [1111b], TRKOPTION:False, SPARE:False, VPBAD:True</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x8F" /> <ParameterType>Custom</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>DEVICE_CODE</ID> <Code>252</Code> <IDAndCode>MFR_44 [0xFC]</IDAndCode> <ValueText>ID: 0x020 (TPS549D22), Revision: 0x1</ValueText> <ValueEncoded xsi:type="PMBusWord" Hex="0x0201" /> <ParameterType>Raw</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>ON_OFF_CONFIG</ID> <Code>2</Code> <IDAndCode>ON_OFF_CONFIG [0x02]</IDAndCode> <ValueText>Mode: CONTROL Pin Only; Control: Active High, Turn off Immediately</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x17" /> <ParameterType>Custom</ParameterType> <ParameterCategory>OnOff</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>OPERATION</ID> <Code>1</Code> <IDAndCode>OPERATION [0x01]</IDAndCode> <ValueText>Unit: ImmediateOff; Margin: None</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x00" /> <ParameterType>Custom</ParameterType> <ParameterCategory>OnOff</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>STATUS_BYTE</ID> <Code>120</Code> <IDAndCode>STATUS_BYTE [0x78]</IDAndCode> <ValueText>CML</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x02" /> <ParameterType>Bitmask</ParameterType> <ParameterCategory>Status</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>STATUS_CML</ID> <Code>126</Code> <IDAndCode>STATUS_CML [0x7E]</IDAndCode> <ValueText>INVALID_CMD</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x80" /> <ParameterType>Bitmask</ParameterType> <ParameterCategory>Status</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>STATUS_IOUT</ID> <Code>123</Code> <IDAndCode>STATUS_IOUT [0x7B]</IDAndCode> <ValueText><EMPTY></ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x00" /> <ParameterType>Bitmask</ParameterType> <ParameterCategory>Status</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>STATUS_VOUT</ID> <Code>122</Code> <IDAndCode>STATUS_VOUT [0x7A]</IDAndCode> <ValueText><EMPTY></ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x00" /> <ParameterType>Bitmask</ParameterType> <ParameterCategory>Status</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>STATUS_WORD</ID> <Code>121</Code> <IDAndCode>STATUS_WORD [0x79]</IDAndCode> <ValueText>CML</ValueText> <ValueEncoded xsi:type="PMBusWord" Hex="0x0002" /> <ParameterType>Bitmask</ParameterType> <ParameterCategory>Status</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>VOUT_COMMAND</ID> <Code>33</Code> <IDAndCode>VOUT_COMMAND [0x21]</IDAndCode> <ValueText>0.900390 V</ValueText> <ValueEncoded xsi:type="PMBusWord" Hex="0x01CD" /> <ValueNumeric>0.90039</ValueNumeric> <ParameterType>Voltage</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>VOUT_MARGIN_HIGH</ID> <Code>37</Code> <IDAndCode>VOUT_MARGIN_HIGH [0x25]</IDAndCode> <ValueText>0.900390 V</ValueText> <ValueEncoded xsi:type="PMBusWord" Hex="0x01CD" /> <ValueNumeric>0.90039</ValueNumeric> <ParameterType>Voltage</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>VOUT_MARGIN_LOW</ID> <Code>38</Code> <IDAndCode>VOUT_MARGIN_LOW [0x26]</IDAndCode> <ValueText>0.900390 V</ValueText> <ValueEncoded xsi:type="PMBusWord" Hex="0x01CD" /> <ValueNumeric>0.90039</ValueNumeric> <ParameterType>Voltage</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> <Parameter> <ID>WRITE_PROTECT</ID> <Code>16</Code> <IDAndCode>WRITE_PROTECT [0x10]</IDAndCode> <ValueText>0</ValueText> <ValueEncoded xsi:type="PMBusByte" Hex="0x00" /> <ParameterType>Raw</ParameterType> <ParameterCategory>Configuration</ParameterCategory> <Page>255</Page> <Phase xsi:nil="true" /> <CustomIndex xsi:nil="true" /> </Parameter> </Parameters> <Other> <Custom_Commands> <READ_VTRACK_REG> <Enabled>false</Enabled> <Label>Vtrack</Label> <Gain>1</Gain> <Offset>0</Offset> <Reference>2</Reference> </READ_VTRACK_REG> </Custom_Commands> </Other> </Device> </Devices> <Sequencing_Config_V1> <Show_Warning_For_Circular_Rail_Dependencies>true</Show_Warning_For_Circular_Rail_Dependencies> <Traces /> <Int_Rail_Defs> <RailDefinition> <Part_ID>TPS549D22</Part_ID> <Address>21</Address> <Name>Rail #1</Name> <Page_Index>0</Page_Index> <Color /> <Ext_Tracking_Mode>None</Ext_Tracking_Mode> <Control_Line>1</Control_Line> <Ext_Tracking_Custom_Source_Name /> <Operation_Event_Times> <Start>0</Start> <Stop>0</Stop> </Operation_Event_Times> <Vout>0</Vout> <Note /> </RailDefinition> </Int_Rail_Defs> <Ext_Rail_Defs /> <Devices /> <Other_Names /> </Sequencing_Config_V1> <Use_Old_UCD92XX_CLA_Gains>true</Use_Old_UCD92XX_CLA_Gains> </ProjectData>
In the mean time, you can use this .xml to creat your offline mode GUI.
