Hi Team,
Could you let me know temperature characteristic of CC pin Reverse Leakage Current of TPS65218?
TPS65218 datasheet shows that CC pin Reverse Leakage current is 500nA (max) under full temperature range.
I think that Reverse Leakage current will increase with temperature rise.
So, I want to understand the temperature characteristic of CC pin Reverse Leakage Current of TPS65218,
To understand the reverse charging current to Lithium Coin Cell Battery CR2450B connected to CC pin of TPS65218.
Thank you.
Koshi Ninomiya
