BQ27425-G2A: BQ27425 question
Part Number: BQ27425-G2A
Hi all Expert :
                     I can not find out program Chem button in bqstudio...
                     Currently FW version is BQ27425G2A.
                     Due to this is my first time use bq27425, my question as below :
                     1.Does bq27425 need to program chem id ?
                     2.How to optimized parameter and send command ? I need to make golden image
                     3.after golden image, which item need check for updating.... like update status, Qmax, ra table ......
                     thanks
  • this device is a ROM device. It is not designed to be used with different chem ids. if you want to use a different chem id then you need to use our flash based gauge. ps review the quick start guide for the device on how to use and configure.
    To program the gauge you need the gmfs file.
    thanks
    Onyx
