When the TPS92691 uses PWM dimming, must the N-channel and P-channel mos be used at the back of the circuit? Is it possible to add only one N-channel MOS to the main circuit, and the gate is directly connected to the DDRV?
2. In addition, use PWM dimming to continuously change the PWM duty cycle to adjust the brightness, and analog dimming to adjust the brightness, which one would you think is more reliable?
