Hi teams
My customer used TPS61099 in a wireless sensor product that is powered from a battery.
In order to reduce the power consumption on the resistor, the customer wants to increase resistance value.
As I know very large resistance value for resistor divider will lead to thermal noise.
Below is my question:
1) What's the common resistance limitation for total upper and bottom resistor? Customer is using 1Mohm configuration, will it have some risk?
2) Do we have any other method to reduce this kind of power consumption?
3) Will a fix output voltage version device of TPS61099 could achieve less power consumption compare to the adjustable version?
Thanks in advance.
