LM5121: Board size for EVM
Guru 11170 points
Part Number: LM5121
Hello E2E,
How much the outline dimension for EVM board?
Our customer is considering board layout.
They are trying to make the same board as the EVM.
ACGUY
  • Hi Acguy,
    Thank you for considering the LM5121. The EVM size is about 105mm x 56mm. The actual component placement excluding the connectors are within an area of 87mm x 50mm. Hope this helps.
    Youhao Xi, Applications Engineering
