i got a faulted PCB from production with TPS53679 not working. I connected the Dongle to get diagnose from Fusion Digital Power Designer and got VOUT UV Fault.
I could not find anything suspicious on the PCB, i also did not find the root cause in datasheet or any other relevant documents on this fault.
Appreciate your advise on possible reasons for failure and where should i look for it.
