Hello E2E,
My customer has found that there is a pull up resistor on the CNTL pin of the TPS544C20 via trial and error. This is causing the node to rise to a higher than expected value and causing the voltage to exceed Vmax on another TI switcher.
What is the resistance of the CNTL Pin?
Are there any issues with having 2 CNTL pins attached to the same node?
Can the internal pullup be disabled?
Thanks!
Russell
