TPS92602-Q1: About TPS92602-Q1 CC & CV mode
Part Number: TPS92602-Q1
Hi TI,
For this part, we know both has function CC & CV, how could we know the LED driver set on CV or CC mode?
Does it base on LED device to determine it work on CC or CV mode?
  • Hi, Johnny,
    We have assigned the related engineer to help you and will reply soon.
    Thanks.
    Kenneth
  • Hi Johnny,
    It depends on the voltage and current of the LED load. If the circuit reaches the current set-point earlier than the voltage set-point, it works in CC mode. If the circuit reaches the voltage set-point earlier than current set-point, it works in CV mode. The current set-point depends on the RLED_SNS resistor. The voltage set-point depends on the resistor divider at OVFB pin.
