BQ40Z50: Max Simulation Iterations for BQ40Z50
Part Number: BQ40Z50
Our battery manufacturer recommended to change the " Max Simulation Iterations" from its default value of 50 to 30.
Their reason was that the WDT reset more often, and they believed that prevents the battery from charging.
Can you help to explain the pros and cons by changing the Max Simulation Iterations to 30 ?
Thank you very much,
Phuoc
  • Max simulation iterations affects the impedance track simulations. Reducing it will reduce the time for IT simulations which means it will stop with greater delta Q. Cons are reduced accuracy. However, 30 really is the default value. I don't know how you have it as 50.
