BQ25120A: Triggering MR doesn't generate pulse on RESET pin
Part Number: BQ25120A
We are pulling MR down and holding it down for more than T_RESET. However, the RESET output pin doesn't generate the pulse it is supposed to (per datasheet). It just stays high the whole time.
Any ideas what might be going on?
  • Yuri,
    Are you holding /MR for the treset duration?
    Can you share a plot and schematic?
    thanks,
    Gautham
  • Hi Gautham,
    We figured what the issue was. We were using a Hall Switch to trigger MR. However, we used the hall switch in a push-pull config which doesn't work. We switch it to an open drain (more like a push button) hall switch and it all started working.
    We now have a different issue. I will start a different thread.
    Thanks for the help
    -Yuri
