TPS65094: TPS650940A0PG1.0 software
Part Number: TPS65094
Dear Sir,
Does have TPS650940A0PG1.0 software(xxxx.json) could be share...
My customer load TPS650941-1.1.json to set-up TPS650940A0PG1.0 voltage, "BUCK2CTRL " can 't output correct voltage(register is set 0.51V, but output voltage is 2.1V)
Buck1 voltage setting & reading is correct.
This is load software not correct ? or another suggestion for Buck2 voltage setting issue?
Please you kindly provide suggestion.
Thanks!
Steven
