Device selection suport
Need support to seclect DC-DC converter for analog design with low signal amplifier. With specification as bellow.
Input 12CV DC,
Output 8V/3Amp
Thanks and Regards,
Mital Pawar
  • Hello Mital,
    I encourage you to first use WEBENCH POWER DESIGNER for your power supply: https://webench.ti.com/power-designer/switching-regulator   .
    From the parameters you specified, WEBENCH will generated several different designs for your supply.  Based on what are most important criteria for this design, you can then sort the choices, compare topologies and parameters, selecting the design that best meets your needs.
    If, after this process, you have additional questions, you can post a new E2E thread based on the device and topology you have selected
    And if everything is clear and you find the design best suited for your product, please Reply here and let us know.
    ~Leonard
